Thread: Oil Leak - help
Old 07-15-2009, 09:56 PM   #1
cgreiner
cgreiner is on a distinguished road
Default Oil Leak - help
I appear to be leaking oil from the engine in the lower, front passenger corner of the engine. It is at the corner and on the side behind the pulley. So, it appears it may be the oil pan seal? However, there also appears to be a screw/bolt a few inches above coming out of the engine that may also be leaking. Would this be the timing belt tensioner?
cgreiner is offline   Reply With Quote
