Crank Pulley
So I got ready to get the crank pulley off to see what's wrong with my crank timing gear, and I found out that the crank pulley is spot welded to the shaft. Seeing as how a Crank shaft is pricey, and the harmonic balancer is over $500 from the stealership, and I don't have the money to go out and buy a JDM motor, does anyone have any idea on how to remove the pulley in a way that may leave the crank and the pulley salvageable?
