Old 07-26-2009, 06:05 PM   #2
corrosivecopper
corrosivecopper is on a distinguished road
You may have a vac line or something. Or, when something like that happened to me in my 89 Daytona turbo, the c clip slipped off the rod for the wastegate so it wasn't allowing the turbo to build boost. Put it back together and it worked fine. A lot of the times, the simplest solution fixes the problem. Check the easy things first and go from there. Hope that help ya a little
corrosivecopper is offline   Reply With Quote
