Thread: Crank Pulley
Old 07-27-2009, 12:05 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
I think the only option is to grind the welding off, the one thing that would worry me; is why it was it welded in the first place.? Could be the keyway slot is damaged in the crankshaft or the shaft damaged. If that’s the case then you will be back where you started.
