it is so easy
yea it is to bad no one will do it because it only takes about twenty mins. drill out 4 spot welds,spread it open replace the bearing/isolator assy then push it back together. if you keep the housing square the mount bolt will take care of welding it back together. the part # is 8588 for the new one.no vibrations after but that was w/my 7m dont know about the 1jz yet
1985 project 1988 w/1jzte/afic/3" stainless exh
