just turned 21 in july. first supra. lovin drivin it everywhere.
..still got a lot of work ahead of me tho.
need driver rear side window + moldings
rear window moldings
windshield - both wipers
antilock light is on - still havent figured out why...
check engine light is on - did diag - code 52
coolant is coming out of the over-flow spew.. so from what i read on the forums im guessing a BHG
needs new rims and tires. [ current rims are bent up - front rims are bent up i know the rear driverside rim is grinded all over the edge - not sure if i should keep them or replace them - what you guys think? ]
as far as the tires. the tires are in pretty good condition except for the rear passengerside is going bald..
stock spoiler on passenger side the fiberglass thats supposed to be attatched to the trunk is broken
figure out why the rear wiper isnt working - replace the rear-wiper
figure out why the rear window washer spray isnt going
i think i have a power steering leak
so far for now i that i know needs to be worked on..
