Old 08-19-2009, 12:12 AM   #1
judodude64
judodude64 is on a distinguished road
Question Car starts then dies. Starts then won't start
Just bought a 88 turbo two weeks ago. Ran perfect when I bought it. Or so I thought. Drove it fine for a week.
After I filled up the gas tank it would not start. Let it sit for a week and then it started up but wouldn't idle and stall whenever I let the rpms drop. The car still seemed to have 100% power when I pushed it. Brought it back into the garage changed the spark plugs, coolant and oil just for good measure.
After I did that I starting up to make sure I put everything back together again properly. (spark plug job is a pain in the ass) Ran for five minutes and then I turned it off so I could take it off the jack stands. Went to start again to drive around a while and I wouldn't start again.
Starters working great. Even sounds like there might be an ignition every once and a while but won't take Hold.
Does anyone have advice about what I should check next?
judodude64 is offline   Reply With Quote
