Old 08-20-2009, 09:07 PM   #3
Dan Swanson
Dan Swanson is on a distinguished road
Default hillbillytuner- head gasket
I hope you are reading your factory repair manual well???
Titan Motors Sports is big on Supra after market parts. I recommend using an after market steel head gasket and head bolts by ARC.
Titan can help you with the thickness after you tell them how much the machine shop removed. Check the block for trueness. Be sure and use Loctite or other like material on the crankshaft pulley bolt and proper torgue.
Dan_______________________________________________ ____________________
Originally Posted by hillbillytuner View Post
ok im building my motor and want to start with a head gasket even tho it dont need it i want to go with a hks HG but i dont no what one to get there's tons of them i dont really want to change the stock comp and my motor is all stock what bore size do i get and thinkness
Dan Swanson is offline   Reply With Quote
