ok so i found out that what i thought was the problem...isnt... that "hose" was actually my speedo cable
....sooo i accidentally disconnected it...i need advice on how to reconnect it
but the hose that i was looking for...i found it...it is about 5-6 inches long with a 90 degree bend in it halfway through....the start of the hose attaches to the block...after the curve it goes behind the block really close to the firewall and attaches to an inlet between the valve covers....and i cannot get the hose clamp off because the squeze part faces the firewall....fml
can you offer any advice on how to remove the hose clamp and how to reattach the cable?
