Oh i see, well thanks alot man. Im not sure if i can afford to do a total block rebuild pistons, cams, crank, ect. so if i can get away with it for awhile then i will wait to do that. And so would the machince shop do all of that for me? remove the motor and dip the block and all??
And yes it is a 3 connection cable tho i havent been able to get underneath it to see were all the connections are. You said the cable was out of the box? as in the transmission?? so the third cable couldve fallen out.
