i am gettin a set of mk4 supra 16x8" rims
and ive already got the rubber...im runnin bridgestone- potenza RE001's 16 x 235 x 45's
tangsuto.
i would suggest that you go 17's, and maybe go a lil thinner on the bak for a coupl of reasons. first im not sure if the 255's on the bak will fit without rubbing (cause im guessing you will b lowering it aswell lol). and also wouldnt cars grip better in snow if they hav less tyre on the road? im not sure cause it doesnt snow where im located in australia, but if it contains conditions like wet weather than you need thinner tyres to dicipate it quicker from under the tyres.
and i reckon 17's because like you said, your streets are riddled with pot-holes, so a smaller rim with a larger tyre wall diameter will b better, so it can take the more of the impact of the pot-holes and that way you dont let the rim take as much of an impact, so less risk of rim damage.
...and when you go to the tyre shop...discuss with them what type of tyres...my bridgestones are really good tyres, but they are mainly stronger in dry conditions, so you mite need to look for tyres that grip better in wet conditions rather than dry
well thats my suggestion, and i hope ive been of some help 2 u.
