After doing some reading on this forum & some actual investigation, I realize I have a few more minor issues:
- Stuck VSV valve, no heat
- Climate control fan only works on Hi speed
- Gear shifter is very loose
- Hood & hatchback shocks need to be replaced
- power antenna not working, maybe it is just not hooked up as there is a Pioneer head unit installed
- Clunking noise when turning sharply
- Needing an alignment, maybe due to the previous symptom
- Rear transmission mount shot
- Eratic speedometer cable
- Driver seat has a lot of "slack" in it.
Well it looks as though I have my work cut out for me. I will get all of the minor things fixed, then have the dent pulled on the quater panel & have it painted back to the factory color. Stay tuned & I will update all of my progress.
