Old 09-11-2009, 03:32 PM   #7
Bossard
Bossard is on a distinguished road
I have a Celica with a similar problem: hard starting as soon as it goes down to say 60 degrees or below. I think it is the cold start injector not working because if I spray a small burst of starting fluid into the throttle housing through the butterfly plate it kicks right off. I have a Celica GTS with a 2.2 liter engine. There is a relay block in the engine compartment with a lid with markings. One of the markings says fuel and there is no fuse or connector plugged in where that fuel marking indicates inside. I wonder what this is for. My other Celica has a two pronged copper connector where this one has none on the same engine. Does anyone think that could be the connection for the completed circuit for the cold start injector?
Bossard is offline   Reply With Quote
