It all depends on how much power you want. I'm just goin to rebuild a ct26 to a 60 trim because i'm only lookin to build between 300 and 400 hp. When I t comes to exhaust, you should try and make all the pipng the same size. So if your downpipe is 3in., go with a 3in. catback. I think the intercooler piping should be the same diameter as the exhaust, but i'm not 100 percent sure on that.
