okay heres what ive done so far checked the codes and cleared all of it I had code 51 i was able to clear that code by splicing the IDL and e2 on the TPS harness and it showed up code 41 so tomorrow morning im going to check for resistance on the two bottom tps and ill post up more stuff and also the leaking was coming from a coolant line i just need to find it...no oil leak
