Old 09-24-2009, 12:08 AM   #1
Chromemoly
Chromemoly is on a distinguished road
Default Tail-Light Conversion Questions
Hello All,
Last night I started to swap in the 89-92 tail-lights on to my 88-Supra. Man, that top middle bolt on the tail-lights is a "pain" to access, and those license plate clips that plug into the harness are a "pain" to release to boot. At any rate, the two tail-lights and the middle license plate panel have been removed from the car. Last night I was examining the new pieces and noticed that the lock assy. is different on the the 89+ center panel. There are two extra mounting studs near the lock assy. that protrude through the sheet metal which will require me to drill a couple of holes. It looks as if the cables that are mounted to the lock assy. are different also. Has anyone made this swap. Can anyone post some pic's of these components installed.
Thanks,
Chromemoly
86.5 N/A to Turbo Project
88 Turbo
69 Z/28
74 Camaro LT
87 GTI
94 EX
tungsten@cox.net
Chromemoly is offline   Reply With Quote
