Fuse/ OIL PRessure
Thanks Bill UK for checking that out for me.
The OIL pressure climbs to about mid scale or 40 PSI when cold which is were it has always been for this model. Rev it up and it goes to maybe 50-60, Hard to tell with these gauges. I am going to install a color after market gauge pod from CDI called the vGauge which will give me more accurate temp and pressure readings. Suction mounts to the windshield.
The fuel pump was disabled by pulling the EFI fuse in the fuse pod. Labeled EFI 15 AMP
My solution tot he dipstick problem was JB WELD. Mixed a little of that and now it don't move. Added a little RTV on top for insurance.
