A big problem with splicing the 2jz loom with the 7m loom, besides being very difficult, is that the 2jz computer works in conjuction with a fuel pump computer as well. Without the fuel pump computer, the 2jz ecu won't do much.
http://www.supramania.com/forums/sho...d.php?p=994419
here at least tho, you'll have the ecu pinout, i can't remember where i found the fuse box pinouts or dash pinouts, but I hope this helps a little.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
