Originally Posted by DarkSupra2.5
A big problem with splicing the 2jz loom with the 7m loom, besides being very difficult, is that the 2jz computer works in conjuction with a fuel pump computer as well. Without the fuel pump computer, the 2jz ecu won't do much.
http://www.supramania.com/forums/sho...d.php?p=994419
here at least tho, you'll have the ecu pinout, i can't remember where i found the fuse box pinouts or dash pinouts, but I hope this helps a little.
thanks mate...alot of help...
so if i wanted to use the 2j ecu, i would have to put the fuel pump computer into the car aswell right?...so why is that so hard? problems with tryin 2 hook up the fuel pump computer?
