Originally Posted by sbualuba
Hi i have a 89 auto N/A... quick question....
Battery keeps dying because my tail lights will not turn off.... any suggestions?
It could be that your having a problem with the lamp failure box it's located in your trunk it's either yellow or white and it keeps the lights on when there is a problem with your lights circutry; did you do a conversion? You can also try replacing you wand for your lights...if that don't work just rewire your lights to a toggle switch.
