Originally Posted by 86.5 7MGE
I have done mine and all you need to do is to remove all of the parts like you was going to change your plugs out and take a 14mm hex socket and remove the hex bolt put the gasket with the RTV on both sides of the gasket and place back in; be careful not to tighten it too much or you'll crack the gasket. Or you'll have to repeat the process. Also, make sure to clean out your spark plug galley from all the oil and replace your plugs with new ones and check your plug wires and replace and or clean off as needed.
but the plugs are only two weeks old, do i still have to replace them?
