Originally Posted by Tony
Well, I've finally done it!
Replaced head gasket, a lot of new parts replaced too. We fired it up and it runs kinda rough and is leaking antifreeze on the intake side between the upper and lower manifolds, and I have no idea where it's coming from
Any ideas?
What head did you end up using? You stated earlier "My question, will a head from a 7MGE fit my 7MGTE?
What kind of head bolts and torque values?
Did you machine the top of the block?
What kind of head gasket did you use?
