Originally Posted by Spudboy
What head did you end up using? You stated earlier "My question, will a head from a 7MGE fit my 7MGTE?
What kind of head bolts and torque values?
Did you machine the top of the block?
What kind of head gasket did you use?
I found another 7MGTE head, had some valves reaseated and the head machined flat, not the block but it was good. ARP bolts to 70lbs, Advance Auto head gasket set.
