Originally Posted by Tony
Well, I've finally done it!
Replaced head gasket, a lot of new parts replaced too. We fired it up and it runs kinda rough and is leaking antifreeze on the intake side between the upper and lower manifolds, and I have no idea where it's coming from
Any ideas?
So what do you mean 'upper' Vs 'lower' manifolds. I have a turbo with only one intake manifold.
I'm sure when you torqued your head bolts you followed the directions and proper order/procedure right?
