Old 09-29-2009, 09:20 PM   #1
bayareasupraboy
bayareasupraboy is on a distinguished road
Default 1989 Toyota Supra Clutch issue
Hi Everyone,
My car is a 5sp that was originally an Automatic.. However now when I press in my clutch, the car wont start.. All the lights come on, but it wont crank .. Now if I compression start it, it drives fine.
I'm wondering what is pressed when you hit the clutch, that makes the car start? I remember a while back I was at a beat shop having some sub woofers put in, and the car did the issue I'm describing, however he guy at the shop reached up under there and said it was a green wire loose.. "green wire".. I'm not sure what this wire is..
Any help would be deeply appreciated. Thanks!
Update: I'm Assuming that its the clutch start switch.. I looked online to find a way to bypass it.. But the way it looks online, isn't how mines look?
Help is there any other way to bypass it?
bayareasupraboy is offline   Reply With Quote
