Originally Posted by Tbredd7
I am experiencing the exact same problem with the 86.5 7mge I just purchased. If you fix the problem please let me know what you did. I am going to start by replacing some vacuum lines.
Right as it sttarts to hesitate I start to smell a strong odor of gasoline I just recently started running 91 grade was running 89 grade or mid grade. I'm starting to think it may be the timing or bad injectors...maybe even both.
