Old 10-03-2009, 11:45 PM   #9
86.5 7MGE
86.5 7MGE's Avatar
Originally Posted by Tbredd7 View Post
I am experiencing the exact same problem with the 86.5 7mge I just purchased. If you fix the problem please let me know what you did. I am going to start by replacing some vacuum lines.
Right as it sttarts to hesitate I start to smell a strong odor of gasoline I just recently started running 91 grade was running 89 grade or mid grade. I'm starting to think it may be the timing or bad injectors...maybe even both.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
