Old 10-04-2009, 02:57 AM   #10
86.5 7MGE
86.5 7MGE's Avatar
Originally Posted by Krem View Post
eh? upgrading the fuel could cause problems? I thought it was if you downgraded the fuel, you were more susceptible to problems?
No, I still have the stock fuel system set up for the N/A. I want to upgrade my system eventually when I get to that stage. But, I was saying that since my injectors are so old they are probably wearing or worn out already thus causing hesitation at times. Or my timing could be off and causing the problem too I have to look into that after fixing my current problems.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
