Originally Posted by DarkSupra2.5
Have you had the alternator checked out? with all the extra stuff you have on there, you probably need a higher output rated alternator to keep the battery charged and run all the electronics you have.
Ditto. Also, do you have a volt meter? I'd rather rely on a volt meter rather than the one in the vehicle. If you have one....with the car on your batter output should be reading somewhere in the 14 volt range, if not chances may be your alternator isn't charging it up enough to give you enough juice for a start.
