hehe, yeah, that has the better trans. you should check and make sure you have a limited slip rear diff. It'll have a sticker that says "LSD" on it right next to the fill plug.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
