Thread: 2JZ Ge vs. Gte
Old 10-08-2009, 02:28 AM   #1
Supra699
Supra699's Avatar
Supra699 is on a distinguished road
Default 2JZ Ge vs. Gte
I am looking to buy a 93-95 supra NA
Is there a difference in the Engine block and head, or is it just the internals that differ?
I plan on replacing all of the internals anyways.
I also know that there are oil squirters for the crank that do not exist on the Ge. would they need to be installed and if so can it be done?
I am aware of the difference in breaks, some sensors, internals, etc.
Breaks will be upgraded.
can I convert a 5spd manual or a auto 4spd to a 6spd manual tranny? and if so do I have to do anything other than just swap the tranny?
I will of course be upgrading the cooling system with an aftermarket radiator and a double fan shroud. new lines, everything.
then I would like to do a twin turbo setup. any suggestions on good turbo combos are welcome and appreciated. It will be my first supra. the MKIV is my reason for getting into cars and I will give it my all. It will be a fully documented build with videos pics and a full writeup.
I am planning on using AEM plug-n-play standalone for engine management, using a wiring harness from a GTE and the necessary sensors.
If there is ayone who has done this, any tips or suggestions would be greatly appreciated!!
MMMM.......Supra
Supra699 is offline   Reply With Quote
