Those aren't stock for an MKiii, I believe. Correct me if I'm wrong but those are from an MKiv and are they 16" or 17"? Bolt pattern should be 5 x 114.3. I have a set of those rims (16" non-turbo) on my MKiii and I'm running 225 in the front and 245 in the rear. Personally I wouldn't go wider than 225 in the front and I might go with a 255 in the rear, when I need to change them.
