If anything, check your valve covers and around the turbo. I hear the valve covers sometimes have problems on the 7ms. Clean up your engine as well, and then check to see where the oil is originating from. That should help you pin point the leak.
1jz-gte swap (Currently spun #3 rod bearings), Apexi high flow filter, Greddy thrust 3" downpipe, N1 3" catback with cat delete tube, 1 peice driveshaft, Bar and Plate intercooler, and 440 JDM 2jz injectors.
Possible 2jz lower block swap in the works if I can't rebuild the 1j. So troublesome.
