Originally Posted by DarkSupra2.5
If anything, check your valve covers and around the turbo. I hear the valve covers sometimes have problems on the 7ms. Clean up your engine as well, and then check to see where the oil is originating from. That should help you pin point the leak.
Yes, check around the valve cover, because if it is leaking there then it could be leaking onto the manifold and burning causing smoke.
