Originally Posted by TurboSupera
Those aren't stock for an MKiii, I believe. Correct me if I'm wrong but those are from an MKiv and are they 16" or 17"? Bolt pattern should be 5 x 114.3. I have a set of those rims (16" non-turbo) on my MKiii and I'm running 225 in the front and 245 in the rear. Personally I wouldn't go wider than 225 in the front and I might go with a 255 in the rear, when I need to change them.
Yeah, stock would be R16/225. As for max width on the back probably want stick with 255. My stock tires cost me $120 a piece, because the 225 width is a "special order tire". I'd have no idea how much 255's would run you.
