Before you re-assemble everything, how is your clutch for your fan? it should be very tight. It should not spin super easy and if you spin it with your hand there should be a lot of resistance. Otherwise if its easy to spin, you wont have your fan cooling as well as it should be. The clutches are around $40 if you need to get one replaced.
