Old 10-19-2009, 12:27 PM   #15
2 months ago i had to replace ALL front pads calipers and rotors, and after that i lost all break power...
Replaced the "Master Break Cylinder" for 75 dollers,never had a problem again...
if you pump your breaks do you get anything???
do they build up over time??
small o rings in the master break cylinder could go overtime causing it too loose pressure thus having no peddle...
chek it out...
