Skip the electric fans, for some reason no one has much luck with those instals and besides, that much current draw makes the alternator work that much harder which makes it harder to rotate.
If you think the stock fan causes too much resistance then look into a flex-a-lite fan, as they spin faster they flatten out reducing resistance... you'll need a different fan clutch too, the stock fan clutch would destroy the fan.
If you smell burning coolant, it's getting out of the cooling system... period. Find the leak.
