Originally Posted by *D-Joker*
also, if your planning on going shorter, i would consider getting shorter shocks aswell, for the simple fact that because the spring is shorter, it throw on the shock will be to long for it, and if you hit a bump and get some air, your spring could fall out (it has happened to a friend) hahaha
Indeed, you're also likely to blow a valve (see broken) in most types of shocks. It's not uncommon to see greatly reduced lifespans in lowered suspension applications... many believe that's why Tokico's Blue shocks don't last well... I don't know how accurate that it.
