not so much a good deal for the first.. i have an 88 that has had some issues but it was only 500 to start i put a jdm in it and fixed alot of leaks and put new interior in it new rims and tires and neon sand ive spent less than 4k also alot of leaks and fixes that are minor problems because i put the jdm in myself 2 years ago, had overheating issues but you should keep looking because their should be a better deal. even if you think you are getting a deal the 88 89 supra likes to break down alott check to make sure it has not had overheating issues and that the headgasket is intact, also check the ball joints they are not fun to fix, and they are usually worn out by now. in most supras it will not have been fixed yet, and within the next 5 years or so they will need it... alot
