Old 10-24-2009, 11:11 PM   #5
Originally Posted by ricerbaby View Post
having the same problem at the moment.. my 88 is doing the same thing. it sounds just like a computer problem, i had a broken coolant hose and it threw coolant and water all over the engine and it got in my cpu which made my car do the same thing. a new cpu unit is pretty expensive... but you can look for one on ebay too...
In your case it very well may be the ECU. Try cleaning out ALL of the harness connectors behind the dash with electrical contact cleaner (Radio Shack carries it as well as most electronic supply shops). If the problem remains another ECU may indeed be in order. What are you driving? N/A or Turbo, Manual or Auto? I have another GE ECU which I know is good.
