Old 10-25-2009, 10:57 PM   #3
suprajim
suprajim is on a distinguished road
Thanks for the help cre. So, it looks like the prior owner connected the wrong tubes, so I will switch those out. The other end of the curved tube was connected to the BVSV. However, I looked again and still could not see the hard line (22205 in diagram) that the tube from the BPV should connect to. Looking at the diagram from the TSRM, it shows the the hard line leads to a hose (22230w). Where does that hose connect to? I'm not sure if the hard line is the only thing missing or I need to get more parts. I am making a list of all the parts needed so I can order them all at one time. The turbo seems fine from what I can tell, no shaft play or anything. But now I'm nervous about any other damage that may have been done.
suprajim is offline   Reply With Quote
