yea, it was a brown plug... but now it's two seperate elec connectors with sleeves around them to prevent contact.. used ohm meter to determine on the old plug to determine which terminal which wire went on.. However, after doing said fix, the car has a harder time starting up cold than it did before and seems more sluggish than it did when this sensor wasn't plugged in correctly... sounds almost opposite of what you mentioned...
