Thread: warming up?
Old 10-27-2009, 01:03 AM   #17
The injector may be leaking. If it is leaking you'd see those issues whether it's plugged in or not. If it's just dumping too much fuel the sluggishness should go away after a minute of driving so the extra fuel is burned off. I'm not sure if it matters which wire is connected to which terminal... if it does then you may have them switched resulting in the injector always being on.
