could this issue be connected to the ERG bypass setup I've described in another thread? basically the purge port on the charcoal canister is plugged to an input to the air intake, just before the intake manifold... it's not plugged into the BVSV. Infact, the plastic light green colored connector for the hoses is broken and needs to be replaced.. I still haven't found a coolant leak, no signs of BHG either... wondering if I'm smelling vapors through there.
Another thing I did notice today, the coolant in the resevoir and the resevoir hose are chillin... not hot at all.. the part of the resevoir hose closest to radiator is, however, hot... due to surrounding thermals. Dunno if that's bad or norm... just thought I'd throw it out since my coolant system seems jacked..
