Re: Bulb Failure Notification
Sometimes (Many Times) I have found that corrosion effects some of the wires, especially the ground straps that are attached to the plastic bulb holders. Also, sometimes the contact nodes on the bulbs have a tendancy to corrode. If you know your bulbs are good, try cleaning all your connections and your dash light may disappear.
 86.5 N/A to Turbo Project
88 Turbo
69 Z/28
74 Camaro LT
87 GTI
94 EX
tungsten@cox.net
