I bought a universal one from autozone.. same cable just needs to be cut to size... Square end with a metal tip and crimping piece.. its the same thing just cut the cable to the right size. Im not 100% sure its to short but the pin only sits about halfway down in the female connector and I put the male end in their and set the cluster all the way down and nothing... should I go buy another cable for like 10$ and try to cut it longer or test the guage and see if its bad?
