89 7mgte swap
So i shelled out 1400 for a 89 supra with a 7mgte swap with the following parts. Also was told the long block had only 5,000 miles on it. It wasnt running when i got it. It ended up being 2 coil packs were dead and the cold starter injector fuel line was split. I put 2 coil packs off my buddies supra on their fired right up on first crank the gauges in the cluster work besides the boost and oil pressure.
good buy?
Hks ssqv blow off valve
Tokico Blue Suspension
Greddy Turbo Timer
ARP Head Studs torqued to 85lbs.
Titan Motorsports Metal Head Gasket
RPS Max Pressure Plate
Toyota Turbo Clutch Disc
1 PC Aluminum Driveshaft-
50 trim CT26 Turbo-
New fuel pump
Racing radiator/Intercooler
pics up tomorrow or sometime i work to much -_-
