If you're mechanically inclined: pull out the window switch cluster; tear it apart; pull the rockers and under you'll see a metal "V" of sorts which is the inner contact of the switch. On the underside of that piece and on the contacts on the PCB you'll probably find it blackened... sand it off lightly and reassemble.
