Really Bad weird starting problem?
Ok so Ive been working on the complete ignition system of this car for a month or so now.. Ive Replaced the key cylinder just cause, battery and starter. now the car has power... and starts sometimes... but wont always start.. I just sat down and finally drove it today and when i parked I turned it on and off about 5 times to see if it would keep starting.. then lo and behold.. It stopped again..Wont crank or turn over at all.. so I tried getting around this.. hooked up a wire from the battery to a switch to the starter... and still no idea it worked once i think.. but now nothing?... I really need help this is my daily driver..? My Ignition wireing is rigged I had to run a switch from its power wire to the acc wire just to give it power. It works fine. sometimes it works completely normal. and now it wont start.. i can obviously push start it but thats not a option.
